MonkCanatella
Multi-click / Multi-button gestures?
Hi,
I'd like have actions like: bottom thumb button + left click = play/pause
Are there ways of having combinations of clicks/buttons perform actions?
I saw this profile  and it says that he has combo-input actions, but they don't actually work.
1 answer to this question
Combination inputs can be created on any input by clicking the small '+ADD' button which appears when you hover your cursor over an input.
I've just checked the profile you linked and the combination inputs it include seem to be working correctly.
Combination inputs like this need to be pressed in the correct order. So for the example you mentioned shown below the Play/Pause command would only trigger when the thumb button is pressed first, followed by left click (while the thumb button is still held down).
Pressing them in the reverse order wouldn't do anything, unless you also created that combination input separately.
