Ramulus
Using secondary click on RMB
Not sure why it isnt working, but I want to deep click the RMB and it take effect. My example would be to use left ALT for a secondary click function for the RMB. I tried using the same configuration for another profile I have but it still doesnt seem to work. Any tips would be great!
4 answers to this question
I just noticed that no other button mappings are working. Such as mapping C to the outermost button next to LMB. I have the profile activated....what happened?
If your Z's 'mouse' type outputs are working (cursor movement, left click, scroll etc.) but keyboard outputs are not. I'd first recommend unplugging and reconnecting your Z, or restarting your PC if that doesn't help.
Ok that works, thanks! But how about the secondary click tied to left ALT? It doesnt seem to do anything unless I am doing the inputs wrong.
