Need More Output Axes
3 axes plus one slider on the virtual joystick output isn't nearly enough for my purposes; I want to map every analog input on the Z (deep clicks, gyro, etc) to its own analog output on a virtual joystick. Is it possible for me to mess with the config files to add more analog outputs to the virtual joystick? Maybe even add more virtual joysticks? Alternatively, is there any way I can get all of the analog inputs sent to a vJoy device?
2 answers to this question
It's not possible to access additional axes by modifying config files, as these are fixed in firmware.
However, if you are a developer it's possible to access the raw analog outputs from the Z. If you link those up to your own virtual joystick you could add as many axes as you like.
The details on how to access the raw sensor outputs can be found in this thread.
