MonkCanatella 0 Posted January 9 Share Posted January 9 I'd like to be able to tilt my mouse and pull the left trigger in order to open the driver window. Is this possible at all? Link to post Share on other sites
0 Zeanon 22 Posted January 9 Share Posted January 9 (edited) One way could be to assign a complex shortcut and the use an autohotkey script to catch said shortcut and open the software. Basically make a script, add it to autostart so it will always run in the background and use something like ctrl+shift+f24(if the Swiftpoint software let's you use f24) as the hotkey for example If needed I could write the script for you. Edited January 9 by Zeanon Link to post Share on other sites
0 Bryce 103 Posted January 10 Share Posted January 10 If you pin the configuration software to the task bar in one of the first 10 positions you can also launch it with the shortcut "WIN key + Number key" (not numpad). For example in the image below it's in the 4th position on the task-bar (not counting the Start button). So "WIN + 4" will open the config window (if it is not already open). Link to post Share on other sites
0 Zeanon 22 Posted January 11 Share Posted January 11 Now that is a neat information to know 😮 Link to post Share on other sites
MonkCanatella 0
3 answers to this question
Please sign in to comment
You will be able to leave a comment after signing in
