Deep Click Calibration
  • 4 weeks later...
Hi @madkurt
The next firmware update is currently looking like it will contain a couple new options to allow the disabling of tilt calibration, and the auto button release fail-safe.
After this there are a few other fixes which we want to add, but once those are in place force calibration will be near the top of the priority list for firmware changes.
  • 5 months later...
Hi Bryce,
7months ago i notice that the deep click percentage are inconsistent for LMB & RMB. While pressing with the same force, the LMB starts at 35% maxing out to 75%. While RMB starts 12% maxing out to 55%. Same with the Left FT,  Right FT and Middle MB.
Now, its getting worse. Deep click for LMB starts at 42% or 50% and maxing out to 68 or sometimes at 75%. Same goes with the other four buttons.
Seems that the pressure sensors started failing (or out of sync). Can we now prioritize the force calibration in the next update please?
Edited by madkurt
  • 1 year later...
Please sign in to comment
You will be able to leave a comment after signing in
