Triggered
how to output Zirkumflex / ^
Hello,
I want to assign the Zirkumflex key ( ^ / ° ) to the Right Trigger but can´t find it.
when i assign ^ as an text String it outputs &
it outputs SHIFT + 6
Edited by Triggered
4 answers to this question
  • 1
If you are using a Non-QWERTY keyboard layout some of the Z's keyboard outputs will be swapped by Windows; since they are always in the QWERTY format.
The way to workaround this is to look at the position the key you want to output occupies on your keyboard, then assign the key that has this same position on the QWERTY layout. Windows will perform its conversion on the output and you should end up with the key you wanted.
For example if you were using the a QWERTZ (German) layout and wanted to output a "^" you would need to assign "` OR ~" from the symbols category instead.
QWERTZ (German)
QWERTY (US)
In text string out put Alt+0 = ^, at least for me but I couldn't produce zirkumflex from any of the symbol keys without and with any combination with shift- and alt-keys.
If you want to output just the symbol as a key stroke it seems it's not available at the time in the symbols menu for keys.
Edited by Tuudi
Thanks i just wanted to output it as a key stroke but seems like i have to work around it
Thanks that works just fine
so its due to me using a QWERTZ keyboard
I didn´t even know there are so much differences between QWERTZ and QWERTY
Thanks for the help
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
