HalcJ5
Really basic question about mappings
How do I add left Trigger Pull mappings on this screen without removing then re-adding everything?
3 answers to this question
@HalcJ5 Currently the only way to get this input back (without manually editing your config file) is to use the "-REMOVE" button near the bottom of the window, then add a new set of blank inputs for the trigger with the "+ADD" button that will appear.
A better solution which doesn't require you to clear the other buttons outputs will be added in an upcoming driver update.
  • Thanks 1
I see. Seems like an odd oversight in the design of the software. Will this update be coming soon?
@HalcJ5 It wont be in the next update (which I'll be releasing very soon), but we have it lined up for the following update which should be out next month.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
