aznsteil
Pressing same Swiftpoint Button over and over again
Hello!
My question: Is it possible to let the mouse presses its own buttons over and over again? I've configured my Left Trigger Push as following, and want it to run like every 10 seconds. Is that possible anyhow, since "loop" only supports one action only?
Would appreciate any answers!
Edited by aznsteil
The output number chosen in repeat function is the output you want the loop to begin from not a single output you want to repeat.
Also you'd need to add a 10 scond wait before the repeat, since you can't define a wait time into the repeat function.
As written above, the repeat function only supports ONE ACTION. I want that the whole sequence to repeat itself after x seconds
In the screenshot above, pushing left trigger runs throught the macro(inputs 1-6) waits for 10 seconds and then runs the macro starting from input 1 through 6 and repeat.
As the times it repeat here is left 0 it will run this indefinetely untill either broke out by an other button press(or maybe on left trigger push realease) or when profile is changed.
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
