DaniusX
Tilt as Scroll
What I want to do is have the tilt function behave as if I'm using the scroll wheel. I get as far as having it work but it behaves as if i only scrolled the wheel one step and I have to retilt the mouse for another step. What I'm trying to have happen is if I have the mouse tilted left then it's as if I'm constantly scrolling down. Is there an option I'm missing to have it loop as I have the mouse tilted? Thanks in advance
3 answers to this question
You'll need to add repeat after the scroll for it to work(and maybe a wait if it's too fast without one). The order should be: scroll -> wait(optional) -> repeat
It would be quite interesting to see, if you could make the scrolling speed some kind of analog
I tried mapping different speeds (more or less delay between scroll) to different angles, but that won't work
Posted (edited)
@Zeanon for analog speed adjustment I'd suggest using mouse movement as input instead of tilting. Unless you want go through making multiple tilt angles with different ammount of lines scrolled.
Edited by Tuudi
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
