smy
Mac installation
Initially worked on Mac (Mojave) with a couple of simple configurations for specific work software. I then connected to a PC to try with other work software with a couple of simple configurations and also worked. I think PC asked me to update firmware (system now says 1.2.54.0).
Reconnected to Mac (latest Mojave) and I cannot get it to work. When I try to start driver I receive message “Mouse has newer firmware. The connected mouse already has a newer version of the firmware. Please update driver”. Cannot get any further.
I have downloaded driver again, updated BTT, tried to reset mouse, etc.
Advice appreciated. Thank you.
According to their Mac driver package, you need to re-flash the firmware with the config that came with the Mac driver package. The profile provided with the Mac driver package have a special mapping that only works with the BTT config they provided, other settings will need adjustments to the BTT config.
Damir.
