Damir
How to configure finger press and scroll then block any other ouputs
1274792653_ScreenShot2019-01-31at08_54_40.thumb.png.a0fc430c29674d9057554ff46cd4f492.png
This is my config:
  1. Right Fingertip on release is Play/Pause.
  2. Right Fingertip deep click 30% is Next Track.
  3. Right Fingertip deep click 50% is Prev Track.
I want to add a new action, while the fingertip is down, and I scroll down or up, I can change the volume BUT I do not want to trigger the Play/Pause. Usually I can use the "Block any other output" checkbox within the config window, but apparently I can't, it is not available. But if I think about it, adding the Block any other output, it will only scroll once before I need to release the fingertip...
Dilema...
Damir.
2 answers to this question
  • 1
@Damir "Block further outputs" is currently only available on release inputs, which scroll wheel and mouse movements inputs do not have. So for now at least you would need to use a different output to avoid play/pause from triggering after a volume change.
  • Like 1
Here is a mapping that will work for you. Instead of each deep click changing a track, they will modify what the scroll wheel does. So at 30% you can scroll through your tracks and at 60% you can change your volume. Each of these allows for continuous scrolling until released. It will then prevent the Play/Pause button from being pressed.
Audio Help.spcf
