wolf
Multiple Tilt Angles
I'm trying to understanding how multiple tilt angles work.  By default there are 2 options. 1.2 degrees and 10 degrees.  But when you tilt to the 10 degrees, the 1.2 degree setting also fires, is there a way to bypass the lower tilt angle when a further tilt is recognized.
1 answer to this question
  • 1
If you want to bypass lower angles you could put the outputs into the return of the tilt instead of the activation point and having stop further outputs checked on the return of the angles past the first one to prevent activation of outputs of lower angles when returnign the mouse to zero angle.
Also putting different vibrations to activation points would propably help detrimine on which tilt angle you are at.
