AODqw97 5 Posted November 30, 2017 Share Posted November 30, 2017 Hi to All Escape from Tarkov is the game I've been waiting many years for. Ultra hardcore realistic gun play and dying simulator. I have managed to take all the important key binds that you need in a hurry i.e check mag, check breach, check weapon, inventory, quick prone, shot steady, switch between sights etc and put them all on my Z Mouse. Not to mention of course the awesome tilt to lean that's not only so simple to use it means you can tilt and move too, not possible with a WASD/QE configuration. Left fingertip key is a single tap to report status, double tap to bring up the gestures command and a 50% press goes straight to check weapon. In my opinion the Z Mouse was worth my purchase for this game alone, it adds so much simplicity to an already frantic game. Here's my config for anyone who's interested. Link to post Share on other sites
CodeBerry 21 Posted November 30, 2017 Share Posted November 30, 2017 I've been keeping an eye on the game as well. Haven't purchased a copy yet but will do after a couple more areas are opened up. Will try out your profile when I do. Link to post Share on other sites
AODqw97 5 Posted November 30, 2017 Author Share Posted November 30, 2017 Nice one To be honest, the four available maps right now are more than enough to keep you going until the next map update which isn't far off now. Be warned this game is a serious baptism of fire and lots to learn! Link to post Share on other sites
RandomNumber 0 Posted December 19, 2017 Share Posted December 19, 2017 (edited) On 01/12/2017 at 9:01 AM, AODqw97 said: Hi to All Escape from Tarkov is the game I've been waiting many years for. Ultra hardcore realistic gun play and dying simulator. I have managed to take all the important key binds that you need in a hurry i.e check mag, check breach, check weapon, inventory, quick prone, shot steady, switch between sights etc and put them all on my Z Mouse. Not to mention of course the awesome tilt to lean that's not only so simple to use it means you can tilt and move too, not possible with a WASD/QE configuration. Left fingertip key is a single tap to report status, double tap to bring up the gestures command and a 50% press goes straight to check weapon. In my opinion the Z Mouse was worth my purchase for this game alone, it adds so much simplicity to an already frantic game. Here's my config for anyone who's interested. AOD_EFT.spcf Mate! Fancy finding you here! I bought a Swiftpoint but had absolutely no luck getting it to work with EFT - landed up looking at the ceiling the whole time. I will defo give this profile a go. Having bought the mouse I'd like it to be a bit more than expensive desk furniture. Edited December 24, 2017 by RandomNumber Link to post Share on other sites
milkman 0 Posted October 23, 2019 Share Posted October 23, 2019 is there any more profiles with escape from tarkov? Link to post Share on other sites
Munkie 3 Posted November 10, 2019 Share Posted November 10, 2019 @milkman Hey buddy, i grabbed EFT back in '16 Just re-installed, will start by using @AODqw97config and let you know!! Here we go again!!! Link to post Share on other sites
Please sign in to comment
You will be able to leave a comment after signing in
