Starstep
Binding a Button to input mouse movement
Hi.
I am trying to configure the mouse to input either mouse movement or joystick analogue input if I click a mouse button. Meaning, if I click Top Thumb button, it would move my mouse cursor 100 units to the right and 20 units up for a duration of X seconds (or equivalent in joystick). Is there a way to do that?
Unfortunately mouse movement can be used as a detector, not an output - which is unfortunate.
You could use AutoHotkey to move the mouse, and activate the key-bind you use in that script with the key you set up for the mouse button in the software...
You can have AutoHotkey also loop it - or you could loop it while held in the Swiftpoint software.
