lunchallot
separate x / y dpi levels
Is there a way to have separate x /y dpi levels when holding a button and return to normal when button is released? I know it can be done on the main configuration screen , but that is for the whole profile. I was hoping  i can do it with a button press.
2 answers to this question
To do this you just need to create DPI levels with the specific X/Y settings you want. Then set the button press to switch to that level,  and button release to switch back.
For example:
You can either jump to a specific DPI level as I have done above, or move up and down levels with the next and previous options shown below.
